Need diagnostic ideas for house battery life
Had our first weekend on the hook over Labor Day. My brand new pair of group 31 deep cycle batteries could not keep the fridges running past the first night. I plan to get in the bilge and check them to make sure I didn't lose a cell on one already. Otherwise I'm running out of ideas for trying to figure out why they won't keep my fridges running for very long. I didn't have the stereo on. Very little is using the house aside from the LED lights in the cabin, and even those I kept on at a minimum. I ran the genny a couple times for 30 minutes and had the battery charger on. I also ran the engines for 30 minutes to try and juice them up. That got me up to about 12.4 volts but they were down to 11.8 in a couple hours.
I checked and cleaned the battery terminals when I switched batteries. I replaced the parallel jumper for the positive terminals as the old one was not in very good shape. I've reached up to where the house connects up to the breaker on the battery panel and it's tight.
Wide open to other ideas on figuring it out.
It's important to actually use the "deep" cycle part of your battery by getting fully charged and then taking it down to 50%, then charge all the way back up.
Here is a site that has some really good info (about half way down in the deep cycle portion).
https://www.solar-electric.com/learning-center/deep-cycle-battery-faq.html/
This past weekend we were out for 4 days on the hook, I ran my genny for about 6-7 hours a day (morning for 2-3 hours, evening for 3-4hrs). I don't adjust my fridges anymore, but I know it did use to help on regular batteries. Now, my batteries are TPPL along with the newer charger, so they charge very fast and definitely hold much better than even regular AGM batteries.
If you have two series 31 AGMs hooked-up properly and charged as per DI's notes you will do well.
That said, @Stodge.....want to really bump-up your battery run time? Add a a third series 31 AGM. That will give you a geometric (as opposed to arithmetic) advantage.
Stodge - did you try turning the fridges off to check the voltage without load? When both fridge compressors are running the load makes my board guage say something much lower than reality.
