Onan generator
PitterPatter
                    Member Posts: 23 ✭
                    Does anyone have a Onan Gen?  If so what is normal water flow for a 3MAJB. Mine seems to be weak and lately I think I am smelling a hot rubber smell. I think it is the impeller getting too hot.
You probably already did this: remove the bowl from the raw water strainer, then open the seacock to make sure water is flowing freely into the strainer.
Once you get it running, check the water temp coming out of the side of the boat as I mentioned above. If it's too hot, keep looking for blockages. For the first month or two, run it a lot. I'd run it under load for 20+ minutes at least once a week. Then back off to a maintenance schedule of 20+ minutes 1-2 times a month.
Good luck!
Next are the points and condenser, if it's that old. Use oem or oe replacements, ive found the China ones may last a season if lucky.
The ones i deal with also have an automotive style coil on them, the ones post points have a pick up unit that can cause a miss when failing.
Last but not least, i tell customers if youre going to guess at a repair without proper diagnosis on these motors go with carb repair first since 80% of the time that's the culprit with small engines.
I dont have any experience with ohv onans.
I have converted an onan generator(rv) engine to run in a large simplicity tractor and the only difference between the two was the tractor engine had a stator behind the flyweel which the genset engine did not.
The points(contact) are what usually goes/gives issues. Filing them creates an uneven surface. If needing to clean i hit them with brake claner then a new clean business card. When possible i upgrade to electronic ignition system as it has less issues/maintaince but i have never converted an old onan, only Briggs and stihl equipment. Oh and an old 289 mustang
