Operating outdrive in trailer mode in shallow water
Spyderweb
Member Posts: 951 ✭✭✭
Ran across this discussion on another boating forum. Poster wanted clarification on whether it was alright to raise outdrive all the way up when going through shallow water. He posted this quote from Merc Manual:
"Never trim the drive unit UP/OUT using TRAILER switch while
boat is underway at engine speeds above 1200 rpm. Use extreme
caution when operating with drive unit raised. Severe
damage to the drive unit may result if unit is raised beyond the
gimbal ring support flanges at engine speeds above 1200 rpm."
I've been boating over 30 years, and the above is the same rule I've always followed. I may back into a shallow beach area, or leave a shallow area at idle speed with drive fully up till I hit deeper water, and assumed I was OK.
The comments from the other posters did not agree. They said either moving parts in drivetrain could grind away at inside of upper bellows, or there was too much strain put on drivetrain when fully up and in gear. They essentially advised to be in gear only when within the "trim" limit". This seems to contradict Mercs advice.
What say you guys?
What say you guys?
There was a recent thread eluding to the same topic.
I responded then, and will again standing by my long-time actions that agree with the quoted statement and you. We often are anchoring in shallow water around a natural sand bar. Coming and going across this area we are in full trailer trim. So long as you are at idling speed (below 1,000RPM in my opinion) and not holding wheel hard over in either direction there isn't any problem.
Have never dealt with any mechanical issues resulting from these actions. One in your column for it being ok.
And, we boat in the same water; I made it down the river 1 time this year. Wanted to get down there again, but season is closing in. Just up the river at Golden Crescent area of Lake O in Henderson Harbor.
Its your boat, sir. Its a risk you're taking with your investment.
Agree with MT.
Agree with rowboat.
This could be a good poll.
Granted, single engine 270, maybe it just sits different in the water.
@reneechris14 , that is what i was speaking of when bringing bellows into the conversation.. if a ujoint grenades, those bellows could take a good piece of it. otherwise, i don't think they near each other.
I been at the boat ramp and seen guy's back in, Start the engine before letting the outdrive down, It make's a awful sound, kinda like a cat in a trap. Growning, squalling. in pain.
I guess i’m a little confused why Merc puts that statement in their manual about this being OK if under 1200 rpm’s.
