Broke top off blue drain plug on water pump
Liberty44140Liberty44140 Member Posts: 4,413 ✭✭✭✭✭
Yep, I did it, couldn’t back out by hand so I used pliers and it broke off. Bummer is that it’s the lower drain hole on the port water pump. I assume I can just drill it out, but what is the easiest way? 3” away from the hole is the stringer so no direct way in. Praying I can do this without removing the entire pump.... suggestions?
