Outdrive trouble
caik01caik01 Member Posts: 39
Looking for the part number for a replacement Solenoid for the outdrive trim/tilt. Pulled the boat and the port outdrive is stuck up. Any help is appreciated
  • IanIan Member Posts: 2,980 ✭✭✭✭
    edited October 2019
    Are you sure it is just the solenoid? I had similar (wouldn't go up) but it ended up being the pump motor. Have you taken a jumper cable and jump to the terminals to confirm?
  • LaReaLaRea Member, Moderator Posts: 7,922 mod
    edited October 2019
    You could swap a solenoid from the stbd side as a test.  I can look up a part number when I go to the boat tomorrow if nobody else answers before then.
  • aero3113aero3113 Member Posts: 9,560 ✭✭✭✭✭
    Here is a Sierra part number from a spare I had on my 242. I can’t remember if this is for trim or the starter, they both might be the same.
