Lights and shore power
If the boat is plugged into an outlet over the winter, will the interior lights still work with the batteries removed?
Post edited by aero3113 on
Now that I think about it, I think I saw a trickle mode on the charger.
I think best to pull them, bring them inside so they don't freeze, and put them on a trickle charger.
Was there a reason to not pull them, other than the work involved?
Unless it was a coincidence and the battery was going bad, that's why I put the black one in temporarily.
So do you assume each engine has a dedicated starter battery, with the genny also using the starboard engine battery? Or does each engine pull off the same port battery (your black battery in picture), and that starboard battery is dedicated to the genny? And then that "Emergency Parallel Switch" combines the 2 batteries when it senses they are getting low and engines need help to start?
1 start battery for starboard
2 deep cells for house and helm
My house batteries are behind the start ones
My genset has enough wire to go anywhere, I have it on the port start battery.
I actually have all group 31 deep cells cold cranking is like 800 or something like that.
