350 MAG MPI fuel code error
Black_Diamond
Member Posts: 5,439 ✭✭✭✭✭
In the process of making my dash digital, I has a sea trial done to make sure all worked. In the process, found out a fault code for the fuel from the starboard engine is popping up and limiting engine power to ~90%. This has always been the engine that under load would drop rpm or no throttle response at higher throttle position when under load (5+ people on board / full fuel / water loads) A lot of the problem for sure was being over propped, that one solved.
This is a 2003 model, Cool Fuel II, only the single fuel pump version. Filters are all good, fuel is good.
Any thoughts to hunt this down? Was not a fuel pressure fault. Something on the electronics side.
The error message was on the starboard side under acceleration and was "fuel pump ckt".
no beeps.
something to consider... much of these EFI systems rely on ohms/impedance for built in tests. an exposed spade on an EV1 or EV6 harness connection (on the injectors) can cause all kinds of grief- especially on boats exposed to hostile environments.
as an example i chased a misfiring cylinder on a mopar 360/408 for literally weeks. it turns out the spade on the offending cylinder's EV6 connector was 'oh but slightly' twisted from some jackalope (me) pushing it on too hard.. it slid into the connect just fine, but the spade didn't sit flatly in contact with it's seat... which caused strange impedance issues but not all the time. also, a spark plug wire running over a harness can also cause some strange issues/readings- meaning there is nothing wrong but the 'reading', which the PCM reacts to as if something was/is wrong, if you can follow that.
