Batteries connected during the winter
So I had grande plans to charge the batteries every month to keep the batteries topped off during the long winter months. Well I haven't gotten down to the marina as often as I would have liked and when I showed up today with my generator, the batteries were dead. I was surprised as they were topped off a couple months ago. I fired up my Honda eu 2000 and charged them for a couple hours and I seem to have a good charge. So this raises a couple questions:
1. How long do you think it would take to fully charge two group 31 house batteries and two group 27 starting batteries? I think I have a xantrex 3 bank charger. Or whatever comes standard on a 2005 FV360.
2. What is typically hard wired to the batteries that would still drain them when the boat is on the hard and all circuit breakers and battery switches are in the off position? I did notice the helm clock was ticking, but I would think that the draw would be minimal?
3. There are two switched breakers on the port side of boat that I'm not sure what they do. They are located by the mounted bell on the backside of the port front seating. So between the the front and very rear seat. Any idea? Could there be other breakers in the engine compartment I may be missing?
I'm just not sure why these 1 year old batteries are being drained what seems to be relatively quickly. Thoughts on what might be the draw on this 360?
there are more things than you think that draw power. If you don't completely disconnect or turn everything off, it's a matter of days before your battery will be dead. CO detectors is one thing that adds as well. The complete drain you did on your house batteries, I hate to say, will make them never be the same. A complete drain is extremely **** them and they will never get that full charge again. (this happened to me the first month I had my boat, I had some outdrive work done and it went on the hard, thinking I had everything off - ended up trading in two brand new batteries)
My thought is, if you don't leave some type of charger on, then just disconnect (takes maybe 5 minutes).
i only have half the batteries you do, but i take them home with me as part of my winterization and charge them once a month until she goes back in the water. then they're always connected to shore power when docked.
i wouldn't go so far as throwing yours away just yet. keep them charged 'til the Spring (as above). Be extra careful once you get back out when the warm weather comes. Or have them tested (auto parts stores do it for free).
You might be OK.
