2013 kohler generator 5ekd??Backfires and stutters
hello everyone. I have the above generator on my 2013 360ec. Since day one it has backfired and stutters. I have had 2 service tech to try to resolve the problem and so far it has been not resolved.
The flame arrester is pretty burned from i guess the backfiring. I have yet to have used this generator because of this issue. Now the tech wants to take apart to get to the pistons and see if anything wrong with the pistons.
Anyone out there that has had a similiar problem and would share the findings.
I dont like the fact that a brand new generator has to be taken apart to the pistons. Not very pleased. Its almost 2 years and still no resolution to the problem. I am not happy i paid big bucks for this option and not been able to use it.
thanks
I second what raybo3 says. Those generators eat plugs like Popeye eats spinach. I even figure in one new set a season in my boat budget. The symptoms you describe are dead on what happens when the plugs go bad OR are not properly gapped.
Good Luck!!
Hamdog
The evil 5e series.
I'll '3rd' on the plugs..even if they look good, replace. I change annually and carry a spare pair. Note there are (2) plugs on this model. Use the correct NGK series too, some places will try to interchange with the lawn mower engine plugs (short nose) based on the engine (marine genset uses the long nose).
Also, try running it from a 1 gallon gas can with premium gas and an overload of gumout or similar (use a separate fuel line from the can to the fuel pump) to help clean out the fuel system.
For you fellers out of warranty, check out MSD, and liven up your ignition heat.. basically you intercept the charge and blast it to upwards of 45~50k vdc.. doing this will allow for a much wider gap on the plugs, which ensures more positive ignition... A matter of fact, NOT gapping the plugs will ensure they don't last long...... Which, uh, may be the case already present in those engines.. you'll not know until you pull them and read them.
When you guys pull and replace the plugs, what do the tips look like? Rich or lean? Worn electrodes or polished white insulators? Just a curiosity is why I'm asking..
Drew, they often look perfect, no wear or 'bad' colors. Thus the replace regardless of condition and it works.
I'm not sure how you would add a MSD on the Kawasaki engine? It uses 2 coils and loops back to the controller.
thank you all for thoughts and comments. i also emailed randy rinker and waiting to see what suggestion he may have. i believe i have been patient enough with this.
I will recommend to the tech all the suggestions that were made here.
at this point, yes i agree, just replace the unit and give a working one.
thanks
Oh yeah............plugs. I can't keep enuf spares.
Hope it's that simple
What state are you in? Most have lemon laws that cover a piece of equipment that has never performed to specs for usually up to 2 years.
I have the FL statute, if you want that. It is 672.608
You basically have an attorney write a letter to the boat manufacturer and the dealer saying that the boat has never performed as spec'd because the generator has never worked. The statute allows you to return the boat and the original sales price is returned. Usually, you give them 30 days to perfect the item or you return the boat. Trust me, they will fix your generator.
