Bottom Wax
RiverRat232
Member Posts: 596 ✭✭✭
What do you use to wax/treat the bottom of your boat that helps keep off crud? I don't want to use bottom paint. Are there other products that you have had success with?
Any wax would be gone in a few miles....but it would look shiney while it lasted.
Personally id barrier coat then ablative coat any boat that spends more than a month or two in the water at a time.
Regular scraping/cleaning by divers doesn't protect an unpainted hull from blisters like a proper bottom coat.
Before it got too cold to wetsand i was removing what was left of my bottom paint. I also have a few blisters to repair but nothing major.
However I didn't do right up under the hull so can't say how that would work or last. I didn't try any plastics either as there really isn't any but I did do the rubber strips around my glass and the aluminum/chrome frames and it worked well. Hull still looked shiny at the end of the year.
http://www.marinediscounters.com/aurora-boat-products-vs721-anti-fouling-wax-450ml-11120/
I'm in brackish water and my season is about 8 months. Water temp gets in 80s by summer. In one month, without paint, you'd have enough growth the boat may not even get on plane. If you have the option, keeping a boat on a lift is a great option.
Where do you boat? What do other locals do?
You will find VS712 on page 4.
https://georgiastrait.org/wp-content/uploads/2015/03/Final_Summary_Alternatives_to_biocidal1.pdf
