Water in the bilge
Seeking assistance with possible causes of water in the bilge on a 2011 310 Express with Bravo 3 out drives and Merc 350 Seacore Engines. Both drives have been pulled and all bellows, gimbal bearings gaskets and trim components replaced. The drives have no play and meet factory compression. The bilge fills up with about 3-4 gals while the boat is docked and currently all seacocks are closed and all systems closed and winterized. The drain plug and drain plug housing is good without water infiltration. Note this conditions exists in dry weather so no rainfall. The water level never goes beyond a few inches of the center strake up to the sides just shy of the float kicking on. I have shop vac everything dry as a bone and the next day the same amount of water as indicated is present. I have tried viewing and can’t see anywhere water may be coming in from. Help is much appreciated, short of purchasing a go pro and leaving it on for 24 hrs in the engine compartment. Note the attached picture shows the water level with oil present. The oil is from the trim reservoir that cracked and leaked which has been replaced prior to the photo.
Thanks
Have you tried drying the bilge and scattering powder such as talcum to look for drip trails? It's cheaper than a GoPro.
Can anyone else with a late model 310 chime in? @jbschmalz23 - Josh, what's yours typically look like?
It came down to pulling the boat, leaving the plug in, filling it with water with the bow high in the air and then pulling on the drive side to side... it only started leaking then. Don't have the official word on what it is yet, but it appears to be some kind of gasket in the transom assembly.
