mascerator pump leaking
Hi - We have a 2001 Fiesta Vee 310 and the macerator pump is leaking. Anyone else have this issue and how did you correct it? I'm looking on Amazon for a replacement pump and can't find a match for Jabsco toilet model 37010-0090. Anyone know if this pump will fit?
  • Liberty44140Liberty44140 Member Posts: 4,401 ✭✭✭✭✭
    I had the same issue with Jabsco electric heads TWICE. On my 2000 center console many years ago I did the rebuild kit twice and could not get it to seal, ended up buying a kit like you posted and that took care of it. Then last spring on my 2006 Rinker 342 I had it again. Kits just wouldnt seal. That boat needed the exact pump you posted, the 37072-0092. You can get them for around $170 delivered.
  • KelleyOpelKelleyOpel Member Posts: 7
    Thanks for the information. We tried replacing the seal also, and it didn't work. I'll order this pump and then let the forum know if it works.
    Hi- I did find the exact pump for the 37010 - 0090 toilet. Some nice person on Amazon provided the partnumber for the pump - Jabsco 37041-0010. That pump lists toilet compatabilities and lists mine. So ordered and will install this weekend. I'll let the form know if it solves our problem.
    Just a word of caution you want more than the pump, you want the whole assembly that the 37072-0092 gives you.
    Hi - installed the pump and it seems to work fine. once we are out I'll be able to fully test it.
