Trim Sender
aero3113
Member Posts: 9,656 ✭✭✭✭✭
My port trim gauge works but only at certain degrees of trim, mostly the upper half of trave and is bouncey. It’s not the gauge, it did it on my old gauge and also with my new one. Has anyone removed the 4 cover screws and cleaned the contacts? I see they sell rotor kit to replace the internals if needed.
https://nuwavemarine.com/oem-quicksilver-mercury-power-trim-rotor-kit-sender-805134a-4/
Post edited by aero3113 on
The adjustments are easy to reset with a helper at the helm.
I ended up buying new ones for about 40 bucks that come with new wiring. Would be a pita to replace with the motor in place.
The wiring on the schematic on paper looks different than the way it is run in the boat
So long as no wires were pinched/broken/damaged during install its probably a bad connection at the bullet ends or its so out of adjustment it maxes out the reading
I removed it a 3rd time trying to figure our why it pegged full. On a trailer on a hill, 4 gallons is less than 2 inches from then top of the tank where the sending unit is located.
