Trim tab mounting screws
Pat310
Member Posts: 598 ✭✭✭
Has this happened to anyone else?
All the screws broke off. Tried to back them out with unscrewums but seem pretty stuck in there. Tech at marina suggested 5200 over old screws and shift tab over a bit and re-screwed. I don’t like the idea of changing location of tab. Thinking drill out old ones filling with thickened epoxy and reinstalling in same location. Comments?
Drilling out each screw will require very steady hands and lots of drill bits.
I'd drill out enough to fill each hole with 5200 and move it over an 1/8th of an inch.
https://www.amazon.com/UNSCREW-UMS-Handy-Broken-Screw-Extractor/dp/B06WLM8K5T/ref=cm_cr_arp_d_product_top?ie=UTF8
really nothing more then a roll pin with saw teeth cut into it. Wouldn’t back out broken screws but was thinking get a little larger and drill out around screw. Will epoxy be strong enough if hole is that over sized?
