Battery gauges
aero3113
Member Posts: 9,657 ✭✭✭✭✭
I just had these questions pop in my head. The port and starboard battery gauges on the dash only read the starting batteries? The gauge on the breaker panel in the cabin reads only the house batteries?
If you look at your port starting battery, there should be a label on one of the positive cables marked “Generator”. Mine has two positive cables - generator and engine.
I guess it really doesn't matter, as long as gen start isn't on the house. That's where my problem lies. House batteries aren't charging while underway, or if they are the charge is way less than what the fridge and electronics suck down. Electronics have intermittent problems after even short runs. Will replace batteries next season, but need to figure out why they aren't charging.
As I told somebody else here recently - either trace each cable from source to load(s), or disconnect each battery one at a time, and see what stops working. Best way to be ready for problems when they happen.
@LaRea, saw you post on disconnecting batteries. No time this weekend. I lost patience trying to trace. By disconnect, do you mean something other than the rotary in the cockpit?
@YYZRC, thanks. Will make that part of checks.
I want to make sure that any problem other than bad house batteries is found and fixed this season.
Question for group: Do the house batteries charge from the engines while underway? I thought they did, but owners around me say otherwise.
DTS controller at the helm
DTS actuator
Trim pump
Those circuits all use much smaller wires. If there aren't any small wires connected to the batteries, maybe there's a subpanel with breakers for those circuits, with a single large wire from the battery to the subpanel.
I'll ask yard to take a look at isolator. Thanks for continued support, folks!
