Fire on board / my Fiesta Vee 242 hardly burned out by an electrical problem at the alternator
On our third day of our autumn boating tour to croatia last year we were in a bit heavy sea when the engine suddenly stopped with a beep tone. My son told me that there's fume coming our of the engine hatch. I thought the engine was maybe overloaded becuase we were running at around 4000 rpm on the boat was fully loaded for our two weeks vacation.
When I opened the hatch, the alternator was burning. I managed to extinguish the fire within the next minute.
Wind was strong and we were just 100meters in front of the rocks. I was lucky that I could drop my new anchor with 50m of chain and the boat stopped at approx 24m depth. We were towed to our harbour later on.
When I inspected the damage, I saw that the plus cable from the alternator to the battery was melted and had contact to the engine block, which created a strong shortage. The cable was burned on the fist 10cm on the alternator side and as well on the first 10 cm on the startor.
For me it looks like the alternator was not the problem. It looked like the plastic on the back side was burned by the fire from the organge wire.
I tought the route cause of this was the shortage. Now I'm going to replace the original design by a different one, which is using an isolator between alternator and the two batteries. I will not go the "old" way through the startor to charge the batteries anymore.
But still I'm thinking if a short was the real route cause.
Meanwhile I have seen that the original organge plus cable between alternator and startor has been cutted by one of the previous owners. They put a piece of red cable in between. So maybe they faced a comparable problem before. I don't expect that the last owner knows that or would tell me.
So I wonder if you guys have an idea or if you had heared about similar problems.
Thanks in advance
Frank
Thanks in advance
Frank
Frank / Fiesta Vee 242 2001 / 5.0 EFI / Germany
We called the coast guard. When they recocnized that the fire doesn't burn anymore, the boat is no more drifting and nobody is injured, they povided us to call a company to pull the boat.
We learned a lot this day. Beeing back at the peer in the evening, we put a little tunny we catched on our BBQ and we were very happy that we survived it. The good thing is, that my 13 years old son now exactly knows what to do in case of fire.
On the next day we rented a 37feed sailboat at the charter base where I am booking since 6 years and we had a good time fishing in the adriatic sea for nealy two weeks.
But back to the problem:
At aero's 242 the orange cable was also cuttet. Did anybody else see that at this Rinker?
But I now will install one, to get rid of this cable from the alternator to the startor.
