Difference in Battery Cable Sizes/designations
Willhound
Member Posts: 4,221 ✭✭✭✭✭
When I added a second house battery wired parallel a few years ago I placed it on the opposite side of the hull for weight distribution. I picked up a set of gently used cables from a local dealer as $$ were tight when I just purchased the boat and although they've worked OK, I think there might be some rot setting in and want to change them. About a 9 foot run to account for routing around the engine bay.
My first question is, what is the difference between wire marked 1/0 AWG as in this link: https://ca.binnacle.com/Electrical-Ancor-Marine-Grade-Wire/c58_206/p8849/Ancor-Marine-Battery-Cable-1/0-AWG-Per-Foot/product_info.html
And just 1 AWG as in this link: https://ca.binnacle.com/Electrical-Ancor-Marine-Grade-Wire/c58_206/p2451/Ancor-Marine-Battery-Cable-1-AWG-Per-Foot/product_info.html
Both are listed as battery cables.
Also, my current set up uses 2 AWG for the parallel connector as well as the wire from the original house battery to the battery switch.
So is there any need, or advantage to using 1 AWG for my new wire, or just stick with #2 ?
So in order of lightest to heaviest gauge it would be 2, 1, 1/0, 2/0 correct?
In general, if you double the length and want to keep the same voltage drop, you should double the cross-section area. That means going up three sizes (from 2 to 2/0).
