VHF antenna mount
Stever00Stever00 Member Posts: 145
If you order one of these make sure they give you the 4 mounting hole dimensions before you buy it. I ordered one and they are not same as on the 97 model boat.  No one wants to drill more holes in side of their boat.
  • Aqua_AuraAqua_Aura Member Posts: 2,651 ✭✭✭✭✭
    I had this issue with my anchor light but I just made the old mount fit my new light. Not sure why you're replacing it but maybe you can combine some parts and make it work with the older holes? The first idea I hade was to use starboard as a base screwed into the old holes on the arch so I didn't have to drill the arch.
  • Stever00Stever00 Member Posts: 145
    This is an antenna mount. Mine broke. Had to replace it New one are not the same.
    I just though that if your old base plate with the holes that line up could be used on your new antenna portion.
