Wanting to plug 15 amp power into boat-problems?
Spyderweb
Member Posts: 948 ✭✭✭
Will be heading up to boat within a few weeks (100 mile trip) to start annual buffing, paint touchup etc. Always wished I could top off the batteries while doing these jobs to better get ready for launch day. Found this 30 amp to 15 amp pigtail to allow me to plug into regular outlet on shore so I could run charger while doing other work.
https://www.ebay.com/itm/352720114461
Then I got to thinking, am I at risk of blowing the (likely) 15 amp breaker to the circuit that I will also likely be plugging my Makita buffer into?
Watts=Amps X Volts or 1800 = 15 X 120. I assume this means I have about 1800 watts available to put on circuit. The PD2130 Charger claims 550 watts, and the buffer at 10 amps would be 1200 watts (1200=10X120). So that's a total of 1750 watts. Though the buffer would be used at less than full speed, hence under 10 amp draw, the startup amp draw is likely significantly higher. So I'm guessing there will be short blasts of over 1800 watts.
Will that trip the breaker?
Would a solution be to unhook some batteries and only charge 1 bank at a time?
Is the real solution to only charge batteries or buff, but not both at same time?
https://www.ebay.com/str/ampupmarineandrvcords
Sounds like I don't have a full grasp of the relationship between volts, amps, watts and breakers (no surprise to me there). But based on your experiences, sounds like I should be ok with what I'm trying to do. At least I feel better about it now.
Post pics of the buff job when done. Boat porn is always good.
Just make sure you turn off the other AC loads, like fridges.
