Carbon minoxide detectors going off!
Hello, I have a 2005 300 FV with twin Merc 5.0 mpi's. We usually travel at 24 mph with the front and side glass up as well as the front bimini. After around 10 or 15 minutes the CO detectors in the cabin go off. If I run the engine blowers full time, which im not comfortable doing they dont go off. Any suggestions?
I have a similar CO det that has a readout and I held it back by the swim platform with the boat on a trailer to test it (while running on a water hose) and it didn't take 3sec to sniff a problem. I don't recall at what level it went off but it didn't take much. Rest assured it'd nearly wake the dead. I also placed it in the engine compartment with the hatch down and the engine AND Genset running and thankfully got no CO leakage detected on the readout version nor my secondary basic house style detector.
Here's a label from a typical home CO det. These min levels are very high and Fire rescue personnel will be in full gear to enter a house at even the lowest levels listed here. I think their threshold is 40ppm for full gear. Your typical home device won't sound for 4hrs after reaching 150% of the EMS max level... Yikes
Be safe. Mike
<script charset="UTF-8" src="chrome://hdv/content/hdv.js" type="application/javascript"></script> The cabin door is far from air tight. I had to add a foam seal around mine to keep the mosquitoes from coming in.
RY It'd take a huge effort with far more than just foam to seal that bulkhead, but in my opinion it should be done (although I haven't). The engine room bulkhead in my 270 has holes and gaps that a kid could crawl through which extend throughout the void between the liner and the hull from stem to stern on the port and starboard sides. I was shocked to think that in a worse case scenario raw gas fumes could infiltrate the entire boat as easily as having the engine right in the cabin and seek an ignition point far away from the higher rated motors/switches found in a typical engine room.
CO is a lot more insidious than raw gas and equally deadly, even for our diesel guys. Of course those cigars could be killin' you too...
CO on the hand is not eliminated as a crew hazard by simply running a blower. Even a tiny exhaust manifold leak can overwhelm a blowers ability to vacate the engine room of gases that can easily migrate throughout a cruising boat with a compromised/marginal fire wall/bulkhead......like many of us unfortunately (and often unknowingly) share.
This became a real concern of mine when I was looking at engine room fire suppression. Like RY I thought I'd just get a little foam to really seal off the compartment....... until I actually got the foam and went in head first to do the job. Yikes, I'd use up the better part of a half sheet of marine ply on that rear bulkhead with a hundred angles in at least 4 or 5 spots (most are now impossibly hard to reach with a screw gun, much less a caulking gun) along with all the trial cuts and control wiring/cables to even get close enough to use foam/caulk. All that said, if I was doing a major engine pull (or was 20yrs younger) I'd make that bulkhead seal a high priority.
A properly sealed firewall/bulkhead would have made the original manufacturing a little more difficult but not impossible and would have most certainly made for a far safer vessel. Sadly, I'm sure it's no less than you'll find in any mass produced express cruiser.
CO migration above deck may be far easier to solve using the simple tips others have shared above. Be safe and keep those CO and smoke detectors well maintained for a healthy season ahead.
Mike
Pick up a can of seafoam from the auto parts store.. (gassers only, ry) :-)
Feed it into the intake manifold while the engines are running via vacuum.. pull an entire can in an engine.. once its infested, kill the engine.. let it sit for 20minutes.. refire engine and enjoy the smoke show.. look for smoke emitting from engine compartment instead of exhaust ports (hub) .. follow it to its source, and there is your exhaust leak..
Wanna see how much exhaust you draft while underway? Do the same thing, but instead of idling, motor down the drink and see how much (now visible) smoke drafts back into cockpit and cabin while underway... The seafoam makes it visible.
