Oval window leak
John41
Member Posts: 114 ✭✭
I could use some advice for my leaky front port window. I have the 342 and I finally had the chance to run a hose on the window and sure enough that’s where the water is coming in. It seems like when you run the water on the glass it really starts leaking. The water is running down behind the vinyl in my forward berth. My question is what’s the best way to stop the water from coming in? I guess I need to start by taking the screws out from inside. If I take the screws out will the whole window come out? Any advice would be great. It’s driving me crazy because it’s getting wet where we sleep and creating some mold in the area. BTW I’m not that handy. Lol
You can't go wrong I suppose with either 4200 or 4000UV but there shouldn't be any sealant on the outside when you're done anyway for the UV to affect. So whichever one you can get your hands on should be fine. Be careful not to get any on the vinyl inside, hard to clean up. I gobbed quite a bit in there and when I pushed the light back in and tightened up the screws I had a bit come out around the outer trim ring that I cleaned up with a bit of acetone.
I pity the future owner (or me) if they ever have to remove that ring, I put a pile of 4200 in there.
