Inflatable pfd maintenance
How often should we be replacing the arming kit on these things?  I've read every 2 years and replace the entire jacket after 10?
Does the arming mechanism go bad?
    Most have an indicator showing if the canister still has pressure. Individual makers likely have recommendations. Don't know if there's a USCG rule in it or not.
    Mine are 5 years old and still showing green on the indicators.
    Yeah mine too still show green.  Was wondering if the dissolving triggers get old and not function properly.
    Don't think so. They're basically like an Al a Seltzer tab. Gets wet and dissolves. If it was bad they'd leak.
    Having said all that I do know lots of people that after two to three years they intentionally jump in to get a feel on how they work and then replace the cartridge and trigger. As for the jacket itself, as ling as no tears or rips or excessive UV damage I think you're good for quite a while.
    Okay.  Cool.  I was going to manually inflate them this weekend and give a good once over.
    Most are not 100% tight and over tome will begin to lose air which is with that have a blow tube to keep full if in water for extended period of time.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,851 mod
    Exactly our plan this spring.  I bought replacement cartridge and trigger...just waiting for warmer spring water! :)
    Great idea to wear one and test it.  Let’s you know how they work.
    As for the CO2 cartridges: they have an expiration date on them.
    I might have known that and forgot. Thanks. Will have to check mine.
