Jabsco 37045 Toilet won't flush out or empty
On my 2002 Rinker 342, my toilet was not flushing as quickly or efficiently as it once should so I decided to overhaul it. I discovered the discharge pump mounting base had some cracks so picked up an entire new motor/impeller/macerator assembly from Amazon https://www.amazon.com/gp/product/B000O8AZOO/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1. I also replaced the joker valve. Upon re-assembly I now cannot get the toilet to pump water out. I am guessing that it is not self-priming. Any thoughts on what I should check next?
Over the years I have replaced this motor twice with no issue.
This time I have double checked the o-ring and took it all apart and re-assembled a few times. I have even filled the bowl higher and tried pumping out for a longer period of time thinking that might help but it did not. I am returning to the boat today with a plunger to try and force the water through everything in an effort to prime the pump. I will double check that my o-ring seal is intact and that the holding tank vent is not blocked.
Any other ideas?
I did notice some calcium build up in the bowl and drain fittings (which I removed). I have even snaked the discharge tube back to the holding tank to ensure there is no blockage
Any other ideas?
any suggestions?
