2000 FV270 350 mag mpi engine issue
All.
Took the boat out yesterday and when getting up on plane I heard a bad knocking. I quickly idled down. Engine seems fine at idle. Hear a bit of a knock when revving in neutral. But when under load around 1800 rpm the knock starts. It is quite bad. I am guessing that something happened to a rod, or rod bearing. Before i start tearing into it. What do these symptoms sound like to others. Just looking for some other thoughts.
Some also describe a failing gimball bearing as a thud thud thud.
The gimball bearing is still spinning in neutral.
Have you drained the oil from the bottom of the engine and looked for metal in the oil?
Im not that good at it but i bet Alswag can tell you if each one has ring wear, leaky valve stem seals etc.
I can only read lean or rich.
I also cant tune a guitar or ukulele by ear
But i have tuned 2 strokes by ear for 20 years. I dont tach out my 2 or 4 strokes.
My issue with using a stethoscope is i can still hear the knocking traveling through the block so i cannot pinpoint where in the block its coming from nor would i be able to distinguish rod knock vs spun main bearing without dropping the pain.
I suppose it would distinguish rod knock from gimball bearing clunk
Marine engines dont use special forged internal parts. They do use special freeze plugs and head gaskets. They also use a marine distributor, alternator, starter and other electric components. A raw water cooled motor will use a different water pump. Many marine vortec long blocks come with a bi directional water pump as v belt drive spins opposite than serpentine. Keep this in mind when buying water pumps
The marine cam on the vortec motors seem to be slightly more aggressive than what comes in a 1 ton truck. In a 20 ft boat you'd probably never tell the difference. In a 10k lbs boat its worth the extra 200 bucks for a better than what came in your boat vortec marine cam
Michigan motorz has good prices in 5.7 long blocks but so would your local speed shop/GM dealer speed shop. These are new not rebuilt blocks, no core change. These new blocks are 2700 to 3200, msrp in your area may be different.
You would need to swap your cam and head gaskets on the on direct from GM motor, I've heard most of the newer crate engines already have brass plugs. You'd have to verify. If closed loop the freeze plugs wont matter although salt air will eat them from the outside if not painted.
The stainless head gaskets are not necessary with closed loop cooling.
Many times the engine failure is due to an external failure and the person swapping motors takes all external parts off old motor and puts them on the new one. This kills the new motor.
So water pump, thermostat, oil cooler, exhaust manifold, risers, intake manifold should all be inspected and most likely replaced. Oil coolers are a great place for shrapnel to gather from the old engine, waiting to jump into your new motor.
Ive seen marine 4 bolt mains, marine 2 bolt mains 350. The 327 motors used back in the 70s, many w were taken right off the corvette assembly line. Under powered but had vette numbers so salesman pushed them.
The 5.0 and 4.3 engines had no choice on mains and we still saw them in marine applications. Some gaskets and freeze plugs as well as cam are swapped out on the assembly line, then given black paint for mercruiser or red for volvo. Then marine bolts are added.
If your machine shop has a great reputation, go with them. I would
If you choose the injector route, call Bruce at fiveomotorsports.com and tell him Drew from bionic mopar sent you. He knows injectors though he doesn't know boats... you'll need to know the fuel pressure and the current injectors... displacement too... he has a table (that he guards last I heard) he can cross reference for not only boring but stroking, boosting, and different pressures and different cam profiles... The pressures and selection matters as some lose their spray characteristics when pressures are changed.... you want sprayers not spitters. He'll likely know off top of his head precisely what you'd need... it'll likely be the difference between 250cc/hr and 260cc/hr as an example...
Its the only time I miss carbs... mpi is superior in every other regard.
I wouldn't think bore would affect tune so long as direct replacement pistons are used, same spec cam and compression is kept equal to original. I don't know 100% so hopefully an expert can chime in.
Don't forget a new oil cooler.
If the tube are just honed/polished, that's another story altogether... same pistons go back in... no additional displacement... but he said 30 over... gonna need new pistons for that. Gonna need to investigate fuel trim and adjust the tables on the ecm to do it right.
Its a popular procedure. I imagine the information is a Google search away.
And thirty ain't much... agreed... but why risk it if its just a phone call? Thats all I was saying.
All, So I pulled the engine and took it home to tear apart. Turns out there was also a crack in the block, wasn't causing any leaks or oil/water issues, but luckily I was able to find a machine shop that had the same block. So they are doing all the work and then I will begin re assembly. Here is my list of new stuff aside from the normal engine related stuff that I plan to do. Any other recommendations.
full closed loop cooling system, engine connector, water circulation pump, exhaust flappers, idler pulleys, oil pump, timing chain,
I was on the fence about the closed loop cooling, but when I saw how dirty the engine ports, intake, etc... were I decided this was worth the investment.
Any other recommendations. I want this thing to be like new when done so not afraid to throw some money at it.
...glad I found it.
