battery and battery charger
Hello,
I'm hoping someone with lots of battery knowledge can help me out. Last year, I purchased a new-to-me 2002 FV 342 and my mechanic put in a new battery charger (Pronautic 1230P). I have 3 banks - 1 battery for port engine, 1 battery for starboard engine, and 2 deep cycle batteries for house. I frequently anchor out for 1-2 nights. My house batteries are draining quickly (down under 10 volts) - in about 6-8 hours running two fridges and the stereo system. Running the generator for a couple of hours doesn't seem to be recharging the batteries much and while the generator is running, the voltage is only around 12.5 volts. If it's charging, shouldn't it show a higher voltage?. Only when the boat sits in the slip connected to shore power for a week are the house batteries back to "normal." Even then, when I disconnect from shore power, I'm showing 12.4 volts. When I had my Sea Ray with a similar set up, I could go a couple of days on the batteries (only one fridge though) without needing to recharge using the generator.
The two engine batteries are flooded cell. The house batteries are "maintenance free". I assume they are maintenance free flooded. The mechanic set the charger for flooded batteries and I wanted to know if that is the right setting? or if there would be any problem having flooded and maintenance free on the same charger set for flooded? The mechanic did a load test on the batteries and found no problem. Could the charger not be fully charging the batteries for some reason?
Thanks,
Dan
Thanks,
Dan
2002 Rinker 342 Fiesta Vee
1998 Regal 2100 LSR
1998 Regal 2100 LSR
Next, remove the cables from the batteries, and check them for corrosion. The connectors and posts should be clean and bright. If not, polish them with emery cloth.
How old are the house batteries? Most people get 3-4 years ... 5 at most.
Your setup sounds fine to me. You should be able to go a full day, maybe run the genny for an hour in the evening. The voltage will be low by morning, but not 10 volts.
Check connections and check output of charger as well. it should be outputting over 13V. Also make sure the charger is set up for the correct type of batteries you have. Pronautic is a good charger (I have one as well).
1998 Regal 2100 LSR
Thanks!
1998 Regal 2100 LSR
