Tip for removing vinyl lettering
LaRea
Member, Moderator Posts: 8,001 mod
I wanted to share an effective way to remove weathered vinyl lettering from gelcoat surfaces. The easy part is removing the vinyl: just warm it with a blowdryer, and peel off slowly. The problem is how to safely remove the leftover adhesive. Here's what I did:
1) Saturate a paper towel with Goo Gone, and rub over all adhesive areas until they are coated with the solvent.
2) Wait 2-3 minutes for adhesive to soften. When you can easily scrape the adhesive with your fingernail, it is ready.
3) The secret weapon: get a white plastic bottle cap from a water bottle. Use it to gently scrub in a circular motion over the adhesive areas. The edges of the bottle cap are sharp enough to remove the adhesive, but the plastic will not damage the gelcoat. Bonus -- the adhesive tends to collect inside the bottle cap, leaving a nice, easy-to-remove ball of adhesive.
My boat had a 40"x20" vinyl graphic that was seven years old. It left a huge gummy mess of adhesive. I was ready to spend hours removing it, but I was done in five minutes.
