Trailer tongue weights and moving boat
Stever00
Member Posts: 145 ✭
Been adjusting, redoing this EZ Loader trailer since I bought boat. Boat was dry docked most of its life and put on this trailer to sell. Not sure if it's one that came with boat but I do know the bunks were not fitted to boat when I got it. Today i made the 4x4 post 4 to one ratio bathroom scales tongue weighing device. By my calculations I only have a 132 lb tongue weight doing 10 % of 5,339 total boat weight. Yes, it's really light! I can lift it up by myself . I should have about 554 lbs on tongue. Specs say 4800 lb empty, 60 gal gas 378 lbs, 5 gal water 41 lbs, stuff on boat 120 lbs, swim platform hanging off back estimate 200 lbs. I'm going to try and move boat forward 1 foot next time I get to the water. Not sure this will shift enough weight to the tongue. Anyone had experience with this? Think that may be limit of how far I can move boat forward. Never thought about till now but that big platform I installed this winter hanging off back of boat has to be multiplying its weight.
Another thought! Keep people off your swim platform when engine is running or you may find them dead from carbon dioxide. Just read the link where the 17 year old girl died from this. Be Safe!
put it this way: if i crank the bow all the way into the winch, there is no teetering on the stern when i climb aboard and when it's unhitched... when there is an inch or more because i didn't pull it all the way in, I can teeter simply by climbing on the swim platform.
go watch a video of a trailer improperly balanced- especially with weight too far rear... it's dangerous- a couple bumps in the road and you'll lose control of that thing as it swims behind you. the only thing, really, you can do when that happens is stop. by the time you realize you're swimming it, the very next second it is out of control.
if you list your model i'm sure someone here trailers one and will be happy to provide you measurements. again, you'll be amazed at the difference an inch or two makes. it doesn't have to be 10%, but 10% is a really good target to aim at.
2 of my trailers have axles that can be moved forward and back. With good jacks and jack stands this can be done but measure/mark twice before doing so to keep alignment
Moving a tower would be much easier. I like having extra tongue weight as I often find myself with 20 lbs or more of ice plus drinks, beer and food on the transom.
Tongue weight for boat trailers should be 10% to 15% of trailer weight.
HUGE pet peeve of mine when I see peeps towing with the wrong drawbar.
Generally, not good to have the transom edge hanging off the back bunk rails.
