Hard Top Project
All, just wanted to share with you a project that I am working on. I am running a little behind due to the cold weather not letting up, but I am finally starting to make some good progress. In this pic, I just finished fusing the two halfs together, as I made them separately, so that I could check fit them in place first. it will sit on top of the radar arch and then use the existing canvas rails for front support. I am making it out of 1 inch foam, so it should be very light and the existing supports that are in place for the canvas I believe will support it without any problem. If all goes well with the front roof and it looks good, i will then start on the back one. I will continue to post updates as I have them. Wish me luck!!
x
gathered all my pictures just to give you an idea of the process that I have used so far.
1. Took some foam and held it against my radar arch and traced the outline.
2. using that foam cutout, I cut out 4 pieces of plywood to match, then screwed those pieces of plywood to 2x4 so that they would sit upright.
3. I then took a piece of foam and with the help of a friend, kind of held it in place where I wanted it, and bent it over the edge of the arch, traced it and cut it out.
4. put the cutout onto the plywood forms and screwed it down, ended up having to come back through and place a couple small supports in because the foam was wavy on the edge, but the extra supports straightened it out.
5. then glassed over a portion of the foam, couldn't really do the whole thing because of the screws holding it down, but I got enough of it that it was able to hold the contour in place
6. After that I joined the two pieces, finished glassing over the rest of the foam, and the final picture shows the roof after the first skim coat. tonight I start sanding my brains out trying to make it look good.
Hoping to mount it up this weekend prior to painting.
Now the question is, what color to paint it? I was figuring white to try to match the radar arch. My daughter says to paint it navy to match the canvas. What would you guys do?
Looks great, good work. How are you going to secure it to the rail, considering with high air velocities when your motors are humming along. I'm thinking if there is an upward pressure, the anchors will go into tension, and so you don't want it to be held just with screws fastened to the fibreglass (material isn't the strongest under tension especially concentrated in a small area). You kind of want anchors that cross through the fiberglass, like a plate to distribute the stress, and then when tightened, it puts the fibreglass under compression.
Also are you going to seal the joint between the radar arch and hard top to ensure water doesn't come back into the cockpit. I'm assuming that was your thought by the fact that you overlapped the hard top, which is a great idea.
I am securing it to the arch with bigger self tapping metal screws and fender washers, and yes I am sealing it with silicon, so with any luck I shouldn't get any leaks
Keep your fingers crossed for me, this is kind of an experiment that I am hoping will turn out well.
x
