Bed Bilge Pump - Where does it get water from?
John342
Member Posts: 19 ✭
I'm the New owner of an 342. I keep it under an roof normally but I moved it to friends the other day and it rained on it. It had more water in the bed bilge than in the back bilge. Where does the water come from that get in bed bilge area?
Get a person outside with a hose while you are inside looking for water. Do one side at a time.
Second issue, there is a cartridge filter that is just after that pump ... I once found that the lid, which is removable to clean out that filter, was not screwed into properly, and was leaking. Close the through hull valve, and make sure that lid is screwed on properly ... if you do lose the water in that valve, you may need to reprime the line with water to get the flow going again.
A few tiny drips (even one drip a second) ... over an hour, it adds up to a lot, almost a gallon. So it might look like a lot of water is coming in, but most of the time these things are just drips.
