280ec battery wiring question
When we last visited our boat (2008 280ec with Volvo Penta D4/260) a few days ago, we experienced some odd problems, the cause of which I think I have tracked down to a failing/failed battery. I say "think" because one thing that is happening does not fit the pattern.
I have always assumed that the anchor windlass is powered from the house/domestic battery and that seems to be confirmed by a wiring diagram that I have, although one or two people have told me that it would be supplied from the starting/engine battery. Can anyone confirm which it is?
Trying to cut a long story short, what happens is everything runs OK while the battery charger is running, but with the charger off if you try to operate the anchor windlass such things as cabin lights, water pump, etc will stop operating. So far so good -- failing house/battery is probably the cause.
However, if you try the windlass switch a couple of times the engine will stop? Now of course we have the Volvo Penta EVC system and as I understand it the two electronic modules receive a stabilised voltage supply from the engine and that should be unaffected by any problems with the house/domestic battery????
The volts to the helm and all instrumentation are lost when the fault happens, but I cannot see why that would cause the engine to shut down, although we do have the optional EVC System Display at the helm??
I should add that here in the UK we are still not allowed to stay over on our boats and so I had very little time to investigate this after we discovered the problem, before we had to travel back home. We will be there again on the 3rd July when we will be allowed to stay onboard and so of anyone has any thoughts or ideas before then, I would love to hear them.
When the engine is running, the alternator is sending current to the battery isolator, which feeds it to the batteries. If the house battery has failed, any current needs will be supplied directly from the alternator, with essentially no help from the battery. Maybe the alternator doesn't have enough capacity to drive the windlass startup surge.
I like your idea that the Volvo Penta EVC might somehow be detecting the heavy demand on the alternator output and interprets that as a fault and shuts the engine down. You might be onto something there -- could that be so??
The windlass and the helm are on the house battery. So when your lights are on in the cabin and you use the windlass, the entire house side of the boat could and probably would shut down. I am not sure if it would cause the engine to stall. Like LaRea, I am not familiar with the VP system. I have a Merc and it never stalled. I would check the age of the battery along with the connections behind the battery panel. You might also consider changing the house and engine breakers. I would also suggest changing your house lights to LED bulbs so there is less draw on the system. I changed all of mine a few years ago and I am happy that I did so. It also helps keep the cabin cooler.
How do I get at the rear of the battery panel? No easy access from inside the engine compartment, so does it just unscrew from the cockpit side?
The panel unscrews from the front. There should not be any nuts behind the panel. If the sealant is still in tact, just slowly pull the panel out. The sealant will come loose. I didn't reseal mine with 3M4000. I just screwed it back in place.
Regards, Nick.
