Water in Oil - Leaking intake gasket?
GordOnTheWater
                    Member Posts: 9 ✭
                    I have a new-to-me 1991 Rinker 236 with a 7.4/Bravo 1. I bought it off a mechanic. He mentioned he'd replaced the seawater pump impeller the end of last season. I had a problem with overheating, which turned out (after a few hours of troubleshooting) pieces from the impeller he replaced caught in the power steering cooler and clogging the water flow. So, I got that cleaned out and got out on the water for the first run with the boat. A good hour and a half of cruising around the lake. I stopped for a bit of a break and within a minute or so, the overheat alarm went off. I got towed home. When I checked it out there was no signs of clogging anywhere, and I found milky oil on the dipstick. According to the book, and the mechanic I bought the boat off of, this is most likely an intake gasket issue. Anyone have any suggestions or guidance?
I got water in my 350 from a slight over heat and killing the engine, this allowed the cold lake water to suck up into the exhaust. Took 3 oil changes and engine flush to get most of the water out.
An over heat can eat the exhaust flappers which is how the water was able to enter my motor.
YOUR story, however, could be pieces of impeller in the elbows allowing exhausting water to stream instead of spit, and stream back into the manifolds and resting on an exhaust valve just waiting to open to be ingested.
Since piston rings are not water tight the water will flow down into the crankcase and mix with the oil.
Thank god it was fresh water so no damage done.
If it happens when running you can bend or break a rod, damage the head piston and or cylinder. Just a lot of stuff. Air compresses, water does not.
Also, a 236 with a BBC??? I have a 235 with 5.7. A 1992 to be exact. I bet that boat moves.
Ras: if you shoved a water hose in your trucks exhaust pipe, it'll do the same thing. Just take longer and more pressure.. park facing downhill, and you'll do it faster. Boat exhaust is just shorter and doesn't have the drops cars and trucks do.
I then flushed my motor out with a blend of gasoline and motor oil a few times. Still took 3 oil changes to get rid of maybe a few pints of water.
Replaced the intake. The mechanic was good, and a mobile guy so he came out to my place to do the work. Half way through the work, a thunderstorm rolled through, along with a torrential downpour. I held a tarp over us and the engine bay while he worked. Got the job done. I think he rushed a bit when checking/resetting the timing, but partly because there was zero water flowing through it. He had to leave (spent 6 hours in my backyard) so I took that troubleshooting task on.
A little troubleshooting and it was clear the seawater pump impeller had completely disintegrated. This was the part he replaced a year before I bought the boat. So, this is why it suddenly started overheating after 1 1/2 hours on the water. I definitely didn't expect that, but it is what it is. There was a spare that came with the boat, so I installed it, and ordered another for a spare. This solved the overheating issue.
I've changed the oil several times, and as far as I can tell all the water is out, and there is no evidence at all of adding water to the oil. The last one I added a can of seafoam, because I believe it will help clean the oil system and also absorb any leftover moisture. So far, I've been in the backyard with the hose hooked up for cooling. Hopefully today I'll get it in the water and verify. After 10 or 15 minutes, the temperature slowly rises up to the 200 degree mark, at which time I shut it down. My theory is this is a combination of using the hose (rather than in the lake) and I think the timing is off a little, which could make it run a little hot. Just a theory, though.
It's time to winterize the boat, as I live in Alberta, Canada and winter is sneaking up on us. I will do 1 more full oil and filter change just for peace of mind (and because I have the stuff already), and drain the block. I will take it to a mechanic for the last part of the winterizing, mainly because I want to get the timing checked and the throttle looked at.....it seems to be a little sticky after the gasket replacement project, and idles high (1300 - 1500) unless I manually push the throttle down.
I also had to replaced the water shutters in the exhaust. Possibly where the water got in, but based on the lead up to the issue on the water, I'm still of the opinion it was thee intake gasket. Either way, II replaced them both. During this process, I realized the ex-owner didn't bother replacing the rubber exhaust tubes even though they are pretty worn out with cracking and hardening. I have replacements on order. I also have replacement on order for the nylon ball/spring/long screw assembly in the cooling system (sis below the thermostat). No idea what is called, but the nylon balls are severely warn so I'll replace that.
Otherwise, I'm fairly certain this boat is finally seaworthy. I'll feel better after the in-water testing.
As I said, I'll hopefully get it in the water today for a shakedown. Beyond that, it will be in storage until next season. I definitely appreciate all the guidance I've received from this group. I've learned a lot about this boat which is the bright side of the experience. I'm sure I'll be back with more questions next year. Have a great winter!
