fresh water pump
patmelpatmel Member Posts: 5
I have a 2005 410 what psi and Gallons per min should the fresh water pump be
what I have now is 10psi and 7gal min
  • LaReaLaRea Member, Moderator Posts: 7,962 mod
    They are typically 3-4 gallons per minute and something like 50 psi.  Does your system have an expansion tank?  (I don't think Rinker installed them from the factory.)  If not, there's no benefit to getting a faster pump.  It will just cycle off and on constantly, which will wear out the pump.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,837 mod
    The expansion tank was the best thing I did in my boat!
  • patmelpatmel Member Posts: 5
