Rinker MTX 210 MB Quart Radio
richg123richg123 Member Posts: 1
Radio was powering and working fine, now cannot turn it on via front panel power switch.  Anyone know why?  Where to check fuses?
    is there a specific breaker. If yes double check that it has not tripped but looks "normal" re set it and make sure it has clicked-on. Some fuses are hard to find if of the in-line type - look in nearby wire looms. Also check grounds. Loose or corroded grounds cause so many electrical head-aches.
