Most efficient way to charge batteries?
YYZRC
Member Posts: 5,366 ✭✭✭✭✭
This has been bugging me.
What is the most efficient way to charge the house batteries assuming no other requirements (eg: at anchor, don’t need any other AC power so the decision to use engine(s) vs genny is purely efficiency based)
1) run the generator to power the battery charger
2) run one engine (70 amp alternator)
3) run both engines (2 70 amp alternators)
Efficiency would be in terms of quickest charge and also fuel burned/environmental impact.
Thoughts?
if you're charging and not just tending (meaning you're tossing max voltage at it.... 14.5vdc as opposed to 13.5vdc) and you have shore power available, a smart charger on the battery side of the isolator is the way to go... throw maximum 'smart' charge at it and charge them in no time.... the 'smart' part is it fluctuates and between bursts it reads the drift... if it drifts a lot it will blast it again- if it doesn't drift much it will reduce the amperage and the voltage and checks it again.... flooded cells charge slower, but even so they still do the majority of the charging in the first 20 minutes of charge.
i have a dewalt charger that can toss 80a at a battery... with it a battery is charged to a decent amount in less than 20 minutes.. it's 'smart'... i may be wrong but i don't think most on-board chargers can do that... they can 'tend' or trickle all day long, but they won't burst charge... and an alternator can toss max amperage (depending on isolator) but not do it 'smartly', UNLESS it goes through the computer/ECU- which almost all newer cars do but i'm not so sure mercruiser or volvo's do.
