320 fresh water pump location
We noticed a constant leak coming out on the swim platform and with a friend determined it was from the fresh water tank overflowing. We believe this is caused by a failed divert-er valve near the fresh water pump that is causing the dock water connection to fill up the fresh water tank and start overflowing. I checked the owner's manual and it wasn't real clear on where the fresh water pump is? Can anyone point me on where to start looking for the fresh water pump and valve I need to replace? Thank you very much
