342 Fuel Sender access
davidbrooksdavidbrooks Member Posts: 1,418 ✭✭✭✭
Gents before i start taking things apart what is the easiest way to access the fuel senders?  Do i have to remove the rear berth?
    Port side you can access under the seat....unscrew access panel and there it is. Starboard side, you need to remove ice maker and then unscrew access panel. Removing Ice Maker is pretty easy.
  • davidbrooksdavidbrooks Member Posts: 1,418 ✭✭✭✭
    @DanD2 thanks. I was hoping that was gonna be the answer. So basically the same as accessing the two holding tanks.
