6.2MX Cold Start
CrewLounge
Member Posts: 92 ✭✭
My twin 6.2's run so rich at cold start they smoke. And, when warm, they are sometimes hard to start. Any ideas how to correct?
your engines are expecting a certain fuel pressure... it trims based on that expected pressure.. do the two engines share a common lift pump from the tank? Is there a chance you've picked up contaminated fuel that has deposited debris (and made obstructions that disallow seating/closing) in the injector(s) basket(s)?
Is this the start of teh season for you? what kind of winterization did you or someone else perform? did you fog or have them fogged? it could be simply that the MAF is buggered up (on both engines due to fogging), and that simple...
It sounds like open loop is the issue, but once it closes your good.. temperature is what prompts the pcm to close loop, which is a simple way to say begin trusting the sensors, and achieve operational temperature where detonation is more predictable.. the pcm controls trim prior to closing loop via scripts/tables that do not change...
Do you have a high idle at start?, or, do you have a sputter and a 'want to die' coughing thing going on? ... Did you fog the engines for winterization? ... Did you clean the throttle body at the end of last season or before this one? .. a rich condition can be attributed to a bunch of things.. you've checked rail pressure, so you obviously know your way around.. because of that, I'd recommend you pick up a can of throttle body cleaner and let your idle air control (iac) have a good bath.. if they are gummed up, and the blades closed (at idle), you could simply be squirting more fuel than the engines have air to blend...
for EFI on MPI engines to work, the PCM has to kick things off with a ballpark trim, that is rich.. it's rich because a predetonation on a cold engine is often a death sentence.. richer is harder to ignite, and the engine is less likely to predetonate on compression or a hot spot inside the chamber if it is south of 13:1 a:f ratio.. Scripts control the trim solely.. those scripts are based off of expectations though- primarily, fuel pressure.
after fuel pressure, which is of extreme importance in EFI/MPI engines, the other sensors that trickle online are the Mass Air Flow or Manifold Absolute pressure sensors... the intake air temperature is important.. the engine coolant temperature is important.. the PCM needs to know the throttle position, so that is important, too.. you may want to break out your multimeter and pull some readings off of the TPS to make sure they jive- but, alas, it's unlikely both engines would suffer from this... all together, these sensors determine the fuel trim based off of calculations the PCM performs......... if those sensors are bordering the outside of an expected parameter, they will NOT kick a code, but they will misbehave and performance will suffer.. The #1 culprit for poor performance, as far as these key sensors are concerned, is the MAF..
here is a cut view of a MAF.. not your MAF, but the technology is similar:
the things are surprisingly delicate... if they ingest something, like a solvent or an oil, they can continue to 'work' (as in not kick a code), but they are in fact toast... they can't be recovered easily, but instead can only be replaced.. the MAF is an absolute key sensor, and comes online and provides data to the PCM almost instantly...
If you have a set of '02 engines that haven't had this thing swapped recently, I'd rec you do it anyway- just for good housekeeping measures... you may find that your problem clears right up by doing so.
Pull your pcv valve and shake them... If they don't rattle, replace them.. there is a chance (albeit slight, and especially so because its both of them) they are gummed up and stuck open, and you're losing vacuum, and siphoning oil off the valvetrain.. Whallah, tough start, rough running, rich, and cleared up by rpm's, and heat due to engine operation..
It's a strange problem, and I think I'm out of ammo by now.. :-)
IAC's have a tiny motor that is controlled by the PCM, and is a learned process- the PCM opens the needle, or closes it to allow the proper RPM at closed throttle condition.. they are opened slightly more at cold start than they are while warm... the little motor gadget opens it and closes it accordingly..
a lot of folks make the mistake, whilst cleaning them, of messing up the mapping of those things.. if the PCM thought they were completely closed the last time it ran, and you remove them and open them slightly, the PCM still thinks they are closed... or.. vice versa... the vice versa likely being what happens most often..
when you clean them, do yourself a favor and clean them carefully, making certain teh washer goes back in, and that they are closed.. then make certain and disconnect your battery(s), and give everything a minute or so to drain down- then reconnect.. this clears the adaptive memory on the PCM, and it goes back to hard scripted tables, and where the IAC is thought to be closed..
I doubt both IAC's would be jacking you up.. the arrestor is an easy discovery: remove them and try to run it.. the PCM(s) likely didn't lose data or didn't corrupt data for those pre closed-loop tables, but they could have.. it wouldn't be the first time it's happened.. which is why I asked if you had two separate PCM's or just one that controls both engines? ....
this is def a curiosity... I'm anxious to see what you discover!
I can't imagine what that would be in this case, though, and then- both engines?
Like Mike said, not having enough air in the compartment could easily cause the issue- but why only at low temperature?
this is a weird circumstance.
I gotta tell you, the more I think about it, the more I think mafs... They often go bad without a code, because the filament lies to the iring, registering decent ohms but only because they're entombed in gunk...
Mopar uses MAP's a lot... Chebby uses MAF's more often.. I had a discussion with Al a good while back and (wrongfully) extrapolated that these (mercs and volvo marine) were akin to the Chevy way of doing things.. and assumed MAF's... still... If they use MAP's, that's were I would look..
MAP's, it's been my observation, are even more sensitive than MAF's...
