Batteri charging on 280 EC 2007
jandavjandav Member Posts: 41 ✭✭
I have questions regarding the battery charger and the generator, how they work with the changing...
I run out of battery this weekend and I started the engine to charge, I can measure the voltage at the generator + pole to 13,6V (is that ok?) but when I measure the voltage at the battery bank I only get 12,3V.
At the harbour I plugged in the 110V and that seems to work, it changed at 13,2V
When I follow the + cabels it ended up in a connections box where I guess is some switch between generator/start battery / usage battery. How does that work?
Thanks for all input...
BR Jan
Best Answers
