Jabsco head pump 37245 service kit NOT correct
IanIan Member Posts: 3,024 ✭✭✭✭
An FYI, the shaft seal on my head pump had a drip and per manual may need replacement every few years. Research found this:
Jabsco Service Kit (37045/245) 90197-0000, Service Kit (37045/245), https://www.amazon.com/dp/B007I8YFH6/ref=cm_sw_r_cp_tai_1zZnFbGVQ23B2
Kit came and genuine Jabsco kit but first thing I see is 4 washers (see pic at link - there are 2 shown) and thought okay, they give you 4. Then the seal itself shaft hole is not round but keyed (again, not like pic) so it’s of no use. Checked with my mechanic and he’d have ordered the same kit.
I will make some calls to Jabsco when I can to find out if I can get the actual part 1040-0000. I did find one to fit based on micrometer measurements of existing seal and shaft from an industrial engineering company near me. SKF unit in attached pic did the trick.
Just a heads up guys (no pun intended)
Post edited by Ian on
