342 Wiring question - FIXED!!
Stodge
Member Posts: 2,738 ✭✭✭✭
OK fellow 342 owner, I have a monster gremlin that just moved in. Pretty sure it's a bad ground. Here are my questions: On the ground block at the transom, I only see 1 heavy (#4 give or take) wire. The rest are fairly small. Is that what you see on yours? Also, is there a separate ground block in the helm and if so, where? I see it mentioned in the wire diagram but that's a logical diagram. I need to know if there is a physical block in the helm and if so where to find it.
Many things are not working, like the engine hatch, blowers etc. My bilge pump works but I bypassed the original neg connection and ran it to the ground block. What I should have done was track down my ground problem then, but the wires disappear into a bundle and parts unknown.
Time to dive into the bilge and track wires....
Post edited by Stodge on
But yes they should look like that perfect example and even if it visually looks good still want to check the screws are tight.
Looking at 342 wire diagram. The 12v outlet (cigarette lighter socket) circuit has a complex path for positive and a single negative connection to a box on the diagram labeled "ground block" Now I don't know if they mean the one on the transom or if there is a block with a nice big wire going to the helm to a mystery ground block.
