Water in oil, Mercruiser 5.7
I have a 93 Rinker 260 with a Mercruiser 5.7 in it that was rebuilt approx. 7 years ago. It sat for 5 years in my garage but I put a battery on it and cranked it over every 6 months or so. I finally got it installed in the boat 2 years ago and on the first trip out only ran it for about 5 minutes and the oil pressure went to zero. I immediately stopped and found what seemed to me as alot of water in the oil. The oil on the dipstick was a lite brownish color and I could see the same after removing the cap on the valve cover. I took it to a marina and they said it needed the exhaust manifolds replaced. $2000.00 later I took the boat out and got about 5 hours on it at low rpms and varying the throttle while doing it. Never got it up on plane. This past week I took it out and after a good warm up cranked it up to about 4000 rpms and got up on plane. Upon start up I had only 30 lbs oil pressure. After running on plane for about 4-5 minutes it seemed to be getting louder so I throttled down and the oil pressure once again went to zero. Checked and once again there is water in the oil. Not as much as first time but definately water. Also there is a small amount of water/oil mixture on the starboard side of the motor and in the engine compartment. So, question is, blown head gasket or cracked block?? Keep in mind it had a complete rebuild and properly winterized after the first summer of minimal run time. Im not sure I want to mess with this or just go for a complete new engine which I dont have the money for this year. Thanks for any help and/or advice on what to do now!!
Intake manifold.
either way, vortecs are known to warp if you look at them wrong.
add to this the mating of aluminum to steel allows for a lot of movement during heating cycles.....
but i didn't know that last one until you offered it was an aluminum eddy..
the only way to tell for certain is to pull it off and investigate the water ports- it's most likely the rear one on the starboard side, which is the most common (rear) and because you said the starboard side was water/oil painted.
head gaskets usually don't let loose oil. a bad intake will- which was my initial tell- usually that happens with the dowel gasket across the valley letting loose. now if you were flooding the engine and intake manifold with water you could see why it would be pushed out.. (an aside, make sure and check the oring on the dizzy too)... running at more than around 900rpm, the engine produces enough exhaust pulse to push out water from exhaust manifolds.. when you come off plane (or rev down) that pressure comes back with a vengeance and can overwhelm the exhaust, but that usually kills the engine quick like (hydro-lock)... an intake on the other hand will run okay cold, but get her to temperature and when the circulating water generates pressure enough to overcome the cylinder pressure (primarily on the intake stroke) GULP... and it chases the same 'leak' on the compression stroke forcing the water into the valley and then crankcase... and it's got to go somewhere- either pushes the dowel gasket out or through the dizzy oring, or even through the PCV and/or fill cap... or..... through where the head gaskets used to be.
it makes a distinct sound when running with a leaking water passage... i don't know how to explain it... it's not louder, per say and at first, it's just different... the loud comes when lifters deflate and things start to clank about- water makes a terrible lubricant.
without a closed system it's almost impossible to pressure test a water jacket... that's unfortunate... without coolant it's hard to see the tell-tale marks water makes across the expanse of metal (on the heads and on the intake manifold), but i bet you can still see them when you take it off.
in addition to the sound, another tell was the engine was good until coming off RPM... that's when you sucked it in and it blew out- relieving you of oil pressure.
personally, i'd stick with the merc intake... they actually flow pretty dang good.. i know of several people who use them in their street machines... and.. they are steel and match the heads and the block. what you have doesn't really hurt anything, but it isn't helping either. if you were in salt water and raw water cooled, that would be a different story. but because of the block temperature you're inviting marrying surface concerns with mixed head/intake/exhaust/black material.... you 'can' get by with it, but your torques better be right and you better check them a few times after initial run and subsequent runs. you'll likely find they don't hold that torque when the dissimilar metals bounce about.
Universal intake bolt pattern for 1969 - 1995 applications
• 4 Barrel Universal Carburetor mounting
• 15 degree carburator flange
• Must use electric choke
• All required mounting and accessories holes are tapped
• Superior runner finish for increased air flow
• CNC machined for exact fit and bolt hole location
• Manufactured of the highest grade of cast iron. Resists salt water corrosion that aluminum intakes experience & corrosion caused by natural gas and other dry fuels
NASCAR ran it for decades for 500 miles at sustained rpms boats will. Never see.
Most big go fast boats have aluminum intakes.
I wouldn't run one unelss closed loop cooled personally. Many have and do.
For water
Lots of oil changes with cheap oil, cheap filters. Plan on 3 to 5 with running time up to normal operating temps the last few times.
I flushed mine with diesel/k1 between changes when i had a quart or two of water enter. Wasn't any need to pull valve covers.
re: water flushing
yeah, change the oil until you don't see it.. K1 flushing is an old and reliable trick to...
matching right parts: I don't know what engine you have... the vortec heads will mount on SBC's, but so will older heads- which will dictate your intake manifold... we gotta identify the heads first. vortec heads have a sawtooth casting on the front of the head.
the one on the right:
but you have vortec heads... the eight bolts give it away (eight instead of 12). they sit at 70* instead of straight up and down, which means it's the later ones. they are designed for a gasket of a certain flavor- it's plastic with rubber lined passages for the ports and water jacket.. they are torqued lightly... 11ft#'s IIRC... IF you're using the right bolts, they bottom out to prevent over torquing- you know what happens if they're over torqued? the same thing they'll do not torqued enough... they'll leak. hence, the 'vortec intake manifold warp' wives tale.... it's not that they warp- it's that folks think they warp because they don't use the proper gasket. the proper gasket (plastic and rubber) is damaged by over-torquing.
re-head gaskets:
did you get hot? you said it was running well prior... this is a close call to decide if you need head gaskets.... i'd almost (almost) say go with what you got, but i'd be worried about water infiltrating the cylinder and the gaskets blowing... so... do a compression test followed by a leak down test... do it with the valve covers off so you can ensure the valves are well closed on the compression stroke... but don't pull those head bolts until you've do this... if you unseat them then you're certain to need to check them. most head gaskets don't like being disturbed after initial crush.
The guys putting the LS motors in the go fast boats, are they ditching the composite intakes? Ive not looked into their builds other stupid priced exhaust manifold and riser kits.
looks like a regular old gasket...... almost. blending the temperature is a big deal especially with the composite intakes.
and, those high dollar go fast guys tear those things down all the time- just like the nascar guys... we don't. we run the dog mess out of them and then park them for a week and expect it to happen again the next weekend without complaint. how many heat cycles does a nascar engine endure? how many heat cycles do the go fast off shore boats endure between tear downs? why is is far more popular to run BBC's in those folks 'recreate' on?
there are more problems with that eddy intake than just the material, anyway. it's not a low end grunt intake- it's a mid to high range where developing the inertia of the mass (air- hence runner differences) isn't as important as it is at low range... there is a reason merc intake manifolds are popular in off road builds, as a for instance, as the off idle flows superbly and follows right up to the around 5kRPM... it falls off dramatically over 5k, which is outside the design envelope of the merc engines but right at the beginning of true performance engines range.
Speaking of edelbrock manifolds, what's the rpm range on the performer rpm vs the high rise torque manifold? Isn't the performer more for street vehicles, more low/mid range rpm perfomance?
Hopefully this is the correct one so I can get it ordered asap.
Thanks Guys!!! You ROCK
@212rowboat would you flow match the intake gaskets if needed? Cutting off any gasket material that overlaps into the runners?
I think that's called flow or port matching.
except on vortec heads it's a great thing... the vortec heads NEED that specific style of gasket (not the phenolic spacer but the ones that fit and clamp with the lessor bolts), and that eliminates opportunity to port match... but vortec heads and manifolds breath good no matter- really well, actually. so long as the cam isn't too aggressive, say under 430 lift.. the flow capability on OE vortec heads and intakes is better than most after-market anything on the old 'double humpers'. which is why they respond so well to headers and increased (a little) ratio rockers... those two little things offer a lot more gain than doing the same thing to a ford modular or 289/302... because those vortecs have the capability to flow as is...
