Stock transducer?
bert_florida
Member Posts: 69 ✭
Hi guys, not sure if any of you ran into this, but on our 2004 FV 290 the transducer that came with it for the Lowrance depth finder has a very small leak, I am sure it has to do with the sealant that was originally used getting old, I am not too concerned as of now because the leak is tiny and I have 3 bilge pumps, the transducer can't go anywhere, so only the water sipping through in between the transducer itself and the hull can come in. However, this must be fixed ASAP. The question is, if I remove the transducer to re-bed the seal with new 4200 or so, it will more than likely break as it is made out of plastic. Does anyone know of a transducer that will work with our stock depth finder? I guess another option is to just plug the hull and forget about the depth finder since we have a nice Simrad unit with its own transducer, but I hate to have stuff in the instrument panel that doesn't work.
Any tips are appreciated.
Thanks!
Bert
Thanks!
Bert
