350 mag mpi fresh rebuild dumping antifreeze into oil pan
Hi all. I just finished a rebuild on a 350 mag mpi out of my 2000 270. Block was cracked so found a machine shop that had extra 880 blocks. I took them everything to check out and got the new block back bored 30 over. Had them check intake and all the manifolds and risers and they said all looked good. While out I also installed a freshwater cooling system a mfh-5320. Just put engine back in boat and began filling the heat exchanger. It took over 3 gallons of antifreeze which I thought was odd. I then ran out. So I figured I had enough in to try to turn the engine over. Before I did I checked the oil again and the oil was all of a sudden way high. So I sucked some out and sure enough all that antifreeze went straight into the oil pan. Any idea how this could be happening? Either I or the machine shop missed something dramatic for all that antifreeze to flow right into the oil pan in literally a few minutes. I’m not sure where to start to try to track this down so any advice would be greatly appreciated. Thanks.
so... unorthodox to say the least... but...
pull the blue plug on the circulation pump and blow some air in there- you'll want the compressor some distance away or using bottled air.. use ye' ol' mechanic's stethoscope- which in my condition is a long handled screwdriver.... use your ear and the stethoscope to see if you can determine where the leak is... if it's enough to pass that much coolant, then it's gotta be big enough to be heard?
i'd like to hold the risers suspect, but that only leads back down to the heads... and even if the valve was wide open there would it defeat the rings as quickly as you describe and flood the pan? ... just doesn't seem right...
other than all that- a cracked block could do it.. but that fast?
i'm all ears, man (no pun intended)... it's baffling other than a cracked intake manifold...
Did you fill the oil fill instead of the antifreeze. It seems silly but it's possible. 🤷🏽♂️
This is a strange situation to be sure. The only thing that holds (or doesn't hold) water is the cracked intake manifold... but even a crack won't leak that fast.... this is a strange one.
You CAN get an aftermarket gasket now that is impregnated metal.... theyre a little thicker, amd once you get to proper tq they wont be bottomed out... you can use the OE bolts (but dont reuse them) TTY bolts, or straight up grade 8 so long as you mind your tq values.
Prediction: you're going to find a mangled intake manifold gasket... you were pouring into the exchange which went to neck and into manifold and straight into valley then crankcase...
Not a lot of folks know about the issues with vortec intake manifold gaskets.... theyre a problem. There is a solution, now, but they were a problem for a while. If you grabbed the wrong kind which don't have the little lips that extend into the water jacket on both sides of the port, you'll have this.... if you over torque you'll have this. If you reused bolts you'll have this... if you used bolts without locking dressing (other than NEW OE bolts and with the OE gasket) youll have this. If you used bolts a thread too long youll have this.
I saw a post on FB where a guy was having issues losing coolant and I remembered that little adage "cracked manifold floods cylinders; bad gasket floods crankcase"... i should have remembered that immediately.
Clearwater has good heads at good prices dressed how you need them... I'd give them a shout.
I'm sorry you're going through this.
