Cranking Battery selection
Wondering what cold cranking amps I need (or even how important they are?) Or "how" they come into play when choosing cranking batteries? I'm going to replace both mine with new and need some advice? Strictly cranking , do marine batteries even come this way? Cranking/Deep cycle combination??? At this point I can't afford the super expensive types or specific brands so I'll probably go to Canadian tire for them and will replace all (cold cranking and deep cycle) with the best available when I have the money to do so. Also on the list is a decent Ronca anchor to replace the CQR that slipped out and sent me close to shore while I was below deck for a bit. Anyhow any and all help appreciated
Thanks so much
Cliff
Thanks so much
Cliff
Group 24 Starting (1000 marine cranking amps)
https://www.canadiantire.ca/en/pdp/motomaster-nautilus-group-24-starting-battery-1000-mca-0102495p.html
Group 27 Starting/Deep Cycle Combo (800 marine cranking amps):
https://www.canadiantire.ca/en/pdp/motomaster-nautilus-group-27-starting-deep-cycle-battery-0102799p.html
https://images.app.goo.gl/9HU7Y6YGMCfwD5iB8
Black box with red wires running to it is the isolator on my 310
I think you need to do some more investigating around the cockpit fridge - it seems unlikely that the fridge would be wired to one of the engine batteries, but if it is, that is not prudent and it should be wired back to the house battery bank.
Is there any chance the cockpit fridge is DC Only"?
Thanks again so much guys!!
