Ac breaker flips on heat/generator
Marine air 16k unit. This is only in heat mode (which I know draws more amps than ac). The last two weekends we left the harbor with the genny running and both the cabin and cockpit units on in heat mode. Two times now leaving the harbor the cockpit unit breaker at the panel has flipped, cabin all good (they are on separate main breaker power lines). The admiral will go flip it back, and it’s fine the rest of the trip, just needs popped back once. I’m going to replace that breaker, but should I replace the capacitor too? Any other thoughts?
handy, schematic of just the unit? Or of the wiring from the control to the unit?
