Winterizing bravo engine questions
PickleRick
Member Posts: 4,283 ✭✭✭✭✭
First year with a bravo. I have a thru hull pick up.
I have already changed the oil and flushed/filled the fresh water (coolant side) of my heat exchanger with new dexcool.
Now im onto the raw water side. I pulled the end caps and drained what little water remained. I then pulled my raw water pick up hose and sucked 3(yes 3 gallons) of marine/rv antifreeze through while running until she spit pink out the outdrive. Manual calls for less than 2 gallons. My after cooler(intercooler) sees raw water to cool intake air temps and i cannot find a drain on it so I figured this was a great way to flush it.
Does this sound like a job completed to you guys?
Just for saftey I had a gallon of antifreeze left over when I got done with my holding tank and macerators so I ran another gallon through.
My god winterizing the holding tank and macerators was smelly disgusting work.
I'm now completely winterized minus my wash down hose but I can't finish that until my new pump arrives. They sent me a 120v and had no fittings. I ordered a 12v.
https://www.hardin-marine.com/p-81079-stainless-steel-lifetime-series-sea-pump-drain-plugs-mercruiser-22-806608a02-8m2000874.aspx
Does anybody spay any anti corrosion stuff all over the engine or not?
If so, should any places be avoided and what product do you use?
It does not dry and leaves an oil residue so it may start to get messy after a few used and as stuff sticks to it like dust.
In your application i think id run the antifreeze directly to the outdrive via muffs and the thru hull at the same time.
Wal-Mart pink rv marine is sub 3 bucks a gallon so over kill wont break the bank. Maybe @Alswagg can chime in as I'm sure he does this in his sleep.
I didn't drain my system after the flush. The pink stuff is a rust and corrosion inhibitor which is a good thing for my heat exchanger as well after cooler. I think come spring time I will flush it with white vinegar before launch to help clean out what little corrosion I saw.
