2009 Rinker 28 Ec rain leaked and 4 inches of water in cabin and bed soaked
85 hours on boat inside like new, last week it was full 4 inches of rain water and under bed soaked. so upset as we just bought it.. it was tilted forward at shop, when we tipped back all the water flooded out under stairs and bed area HELP, the vinyl is peeled away from water at side of bed wall from water too. and the cabinet perm damaged water
. WTF where is it leaking. HELP
It's the track for the sliding door as water gets in there it is supposed to drain to the right and out the drain on the side. It can probably allow a couple of inches but the boat certainly should not be bow low. Also make sure your drains are clear and it can allow the water out
Not sure there is a better way to fix the "design flaw" other than it would help if there was a drain also below the track on the left side when facing the door.
I know the rain was absolutely crazy here the last few days so I'm not surprised that happened with no cover and now down.
I got them from SeaDek I have the template number if you wanted to order them. It was $1800.
When I bought the boat there was a little water in that storage area and that's why,it has never happened since then though.
And I agree, leaving it outside without the canvas on is just nuts. All those electronics getting exposed ... not good.
