Engine wont pump water!
Marcdohc
Member Posts: 58 ✭✭
Hello all,
My boat, 05 FV 300 with Merc 5.0's
My problem, Last year for the last couple times out I noticed the starboard engine was reading cold. I figured it was the gauge, it seamed to run just fine. I posted this issue last fall and you folks said install a new thermastat, so I did. When I went to winterize the engine I notice that there was barely a spit of anti frieze coming out of the exhaust. Well, I just hooked a hose to the outdrive to crank her up and noticed there was nothing coming from the exhaust. So I took the thermastat out and dropped it in a pan of hot almost boiling water to see if it would open and it did. So I installed again, but this time I took apart the other one on the port engine so I could make sure I did it right. But still no waterflow. I than opened a winterizing plug at the bottom of the engine and ran the engine and after it sputtered a bit from the hole it then poored with a steady flow. I thought I must of found the airlock and fixed it. After I installed the plug again I ran the engine again and still no waterflow. I then pulled the upper winterizing plug on the raw water pump and ran again and got no water flow. I then pulled the plug at the top of the thermastat housing and ran and no water spouted. Any ideas what it could be? By the way the raw water pump was installed new last year.
Thanks for reading, Marcdohc
