2011+ 310/320 Engine Hatch Question
TonyG13TonyG13 Member Posts: 1,355 ✭✭✭✭
I'm planning on replacing my sound deadening / heat shield on the engine hatch this winter.
Can I raise the engine hatch to its limit, then pull the cotter pin out and manually open the hatch all the way back to a 90 degree angle (resting on the back seat)? If so, any special considerations I need to worry about?
Also, has anyone else replaced the heat/sound shield - and what did you use?
