2011+ 310/320 Engine Hatch Question
I'm planning on replacing my sound deadening / heat shield on the engine hatch this winter.
Can I raise the engine hatch to its limit, then pull the cotter pin out and manually open the hatch all the way back to a 90 degree angle (resting on the back seat)? If so, any special considerations I need to worry about?
Also, has anyone else replaced the heat/sound shield - and what did you use?
Take a look at Soundown products, like this:
https://www.fisheriessupply.com/soundtec-sound-insulation-vinyl-foam-barrier-composite
Mine is starting to fall away from the decking, so tomorrow I was going to take it off then I'd get a better idea of what to use.
Still wondering about opening the hatch to the full 90 degrees by pulling the pin.
On the 342 and the 370, you can open the hatch 90 degrees by pulling the pin. It's required if removing the engines, and I'd guess they are all built that way.
On a side note, I took off the insulation which was basically 1/2 foam with a metallic heat shield. Almost exactly like the one from Jamestown...
https://www.jamestowndistributors.com/product/product-detail/11868
I think I may look around for something more robust like the others we mentioned.
After I took the foam off I noticed a huge hole (~5") in the starboard aft portion of the hatch...
...looks like it goes up into the inside portion of the seat. Definitely not visible from above. Anybody know its purpose in life?
Anybody with a late model 310/320 have a hose going to that hole?
@Handymans342 started a great thread about this a few years ago. It helped educate a lot of us, including me.
